Hi, I’m fairly new to this (both the site and travel routers). I know many people have experienced issues with captive portals, and the goto answer appears to be
config rebind_protection ‘0’
But, I can’t get this to work. The captive portal attempts to open, but nothing loads. I’ve even tried logging in on a device, then cloning my MAC address to no avail. I’m at a loss.
alzhao, I should have mentioned that I have tried both v2.263 and v2. 27 using the GUI as well as manually editing /etc/config/dhcp. Neither has worked.
The captive portal is in a dorm room, not a hotel, and it requires username and password to enable internet access, but is restricted to one device per account. I’m not there at the moment, but I’ll try to get a screen shot later.
I’ve solved the problem with the captive portal (somehow, I’m still not sure exactly how). If I ssh into the router, it’s definitely connected to the internet. Now the problem is that I cannot access the internet from my private wifi network.
