- “Opening the captive portal will cause the block function to fail.”
What does this mean?
- How do you configure which radius server to auth to?
Open thread for discussing questions and answers about captive portal.
Thank you!
Thank you!
Both portal and block are implemented by firewall rules, and the previous rules will match first, which is a BUG.
Radius server configuration is not currently supported.
