Help
. Im trying to write script to auto login to our holiday site captive portal for when it logs the session out. Ive got the logic of the script working with the exception of the command to pass through the authentication. The site url does a redirect to get to the login page. I’ve tried passing both urls and the script is erroring with the below. Ive tried the nubifi and hslocal urls. Where im i going wrong?
TIA
Access captive portal and login
Response=$(curl -s -o /dev/null -w “%{http_code}” -d “username=$USERNAME&password=$PASSWORD” “$CAPTIVE_PORTAL_URL”)
-ash: 200.: not found
Mon Dec 16 16:48:24 WET 2024: Failed to log in to the captive portal. HTTP response code: 000
<body onLoad="document.form1.submit();">
Se est▒ redirigiendo a la p▒gina de login
<form name="form1" action="http://portal.nubifi.com/ **********n.asp" method="post">
<input type="hidden" name="hostname" value="hslocal. Info">
<input type="hidden" name="identity" value="*************">
<input type="hidden" name="login-by" value="">
<input type="hidden" name="plain-passwd" value="no">
<input type="hidden" name="server-address" value="1.1.1.1:80">
<input type="hidden" name="server-name" value="18-FD-74-8C-xxxxxx">
<input type="hidden" name="ssl-login" value="no">
<input type="hidden" name="interface-name" value="BRIDGE-VLAN10">
<input type="hidden" name="link-login" value="http://hslocal.info/login">
<input type="hidden" name="link-login-only" value="http://hslocal.info/login">
<input type="hidden" name="link-login-plain" value="$(link-login-plain)">
<input type="hidden" name="link-logout" value="http://hslocal.info/logout">
<input type="hidden" name="link-status" value="http://hslocal.info/status">
<input type="hidden" name="link-orig" value="">
<input type="hidden" name="domain" value="">
<input type="hidden" name="ip" value="192.168.34.178">
<input type="hidden" name="logged-in" value="no">
<input type="hidden" name="mac" value="96:83:C4:06:xxxx">
<input type="hidden" name="trial" value="no">
<input type="hidden" name="username" value="">
<input type="hidden" name="idle-timeout" value="">
<input type="hidden" name="idle-timeout-secs" value="0">
<input type="hidden" name="limit-bytes-in" value="">
<input type="hidden" name="limit-bytes-out" value="">
<input type="hidden" name="refresh-timeout" value="">
<input type="hidden" name="refresh-timeout-secs" value="0">
<input type="hidden" name="session-timeout" value="">
<input type="hidden" name="session-timeout-secs" value="0">
<input type="hidden" name="session-time-left" value="">
<input type="hidden" name="session-time-left-secs" value="0">
<input type="hidden" name="uptime" value="0s">
<input type="hidden" name="uptime-secs" value="0">
<input type="hidden" name="session-id" value="">
<input type="hidden" name="var" value="">
<input type="hidden" name="error" value="">
<input type="hidden" name="error-orig" value="">
<input type="hidden" name="chap-id" value="\276">
<input type="hidden" name="chap-challenge" value="\114\260\370\270\077\072\057\161\134\077\131\126\226\300\375\362">
<input type="hidden" name="EjecutadoLogin" value="SI">
</form>
</body>
200.
root@GL-MT300N-V2:/tmp/log# ^C
