im trying to find out how to see the cellphone tower ID so i can connect to a tower by the ID, but when i scan i get numbers like
1c781712f 310-60 (n41 273). open signal has tower ID numbers way different. Am i doing somthing wrong?
This might help?
And maybe this one as well:
i am facing same issue
@fermoric @kkvpn
What tool did you use to scan the tower?
The CELLID displayed on X3000 is in hexadecimal format, while the CELLID displayed on the phone is in decimal format.
I used the user interface to scan for the tower.
i think the app to locate the towers are just outdated, i wish gl-x3000 had some kind of map or exact coordination
Hi fermoric:
Please login via ssh and help to exec the command:
gl_modem -B 0001:01:00.0 SAT sp 'AT+QSCAN=3,1'
Thank you very much for you feedback.
It needs information on all the cellular and their distribution.This can be difficult.
