Does the cellular mode of Flint 2 support SIMCOM-8200G? My SIMCOM modem works via USB at least on my Windows device with drivers installed so Im wondering if Flint does also support it.
Flint 2 kernel version is 5.15, OpenWrt 23.05.
It should be supported if SIMCOM-8200G is old and popular.
Do you have the USB device id of it?
Here are the COM ports that are appearing when the USB is plugged in.
0NVEMEA COM PORT:
USB\VID_1E0E&PID_9001&REV_0414&MI_01
USB\VID_1E0E&PID_9001&MI_01
AT PORT:
USB\VID_1E0E&PID_9001&REV_0414&MI_02
USB\VID_1E0E&PID_9001&MI_02
It is not supported 99%
