Is there any way, without using SSH, to view cellular modem connection history on routers with cell modems (eg. X3000)? Specifically looking for a list/log of when modem connects/reconnects so I can see whether or not the connection is stable or if it’s bouncing between bands/towers. Would be awesome if this list/log also included cell IDs.
Hello, Goodcloud stores cellular historical signal records for up to 45 days, including signal strength. You can query such information via Goodcloud.
As for other information such as bands, CellI IDs, etc., router doesn't store such information. If necessary, you can create a script and use command to query cellular connection details you require.
