Certificate for KVM
One of my main concerns about Comet is it's custom certificate. I don't like the fact that the certificate is a self-signed one (I believe that each company out there should have their one intermediate CA and sign the certificates of their products but that's another discussion).
However, for me it's very important to have my own CA's certificate on it. My concern is not how to install it, I am pretty sure it will be similar to MT-6000 for example, but how I maintain it after firmware upgrades. Are there any plans about it?
It seems to be a bug in logic processing, which will be fixed in future versions.
In addition, we are developing the function of direct web access, which is expected to be provided to users in July. At that time, users will receive a free signing certificate
Any updates on this topic ? I don't really like that we can't change the certificate either, specifically considering that the self-signed integrated one is showing Moscow / RU…
New beta test firmware: 1.4.0 beta1 for RM1(Comet) Version 1.4 will allow users to permanently retain custom certificates
Nice, thank you !
the certificates located at /etc/kvmd/user/ssl/
Yep, thanks, I eventually found it (after a ps auxwww in the shell to find the nginx instance and its configuration file). I changed it, it works.
How can we do this?
