You can try finding a tunnel, but you still need ipv6 as endpoint.
Ipv4 can only communicate with ipv4, and ipv6 only with ipv6.
Such tunnel forwards or converts ipv4(lan) to ipv6 (destination wan), such tunnels are called 4in6 for ipv4 to ipv6, but you also have 6in4 from ipv6(lan) to ipv4(destination, wan), i could be mistaken about the two namings they could be doing both equally the same ipv4->ipv6(wan), but i do know they are tunnels.
Hello, after 15 days the provider has 'degraded' my modem and now i do NOT have cgnat anymore but IPv4.
I can access my home by the Wireguard server as is was before.
When I use internet while using the WG server connection, I thought that in the old case, the AGH was also blocking publications for the devices which were connected through the WG VPN but now, I still have pubs on my phone, while connected through WG.
