Hello ,
I have the GL-X3000 modem ,
I have this error :
SIM card not registered
I tried change the imei but not worked!
So I think I should chanhe QMC protocol to QMI but i don’t now how can I change it , can any one help me ?
Hello ,
I have this error :
USB Protocol doesn't matter when doing magic (imei modification). It should work as intended. Can you double check your command since you might be using the wrong characters for double quotes?
AT+EGMR=1,7,"fill_imei_here"
