Changes planned for JSON-RPC (Router 4.x) API?
There were JSON-RPC (Router 4.x) API documentations on https://dev.gl-inet.com/ but currently it's closed and for almost all this year.
Because of I'm going to use the JSON-RPC API, so I'd like to know if there are any plans for significant changes near soon, or if just the public website is closed.
To be clear, I'm not asking for API documentation, and just want to know if the current API will remain similar as now for some while.
Thanks.
Regarding the closure of the API, here is a before detailed reply.
The APIs will not be change in small versions (such as v n.1.1-n.9.9), but probably added or deleted in major versions (v 3.x.x, 4.x.x, 5.x,x)
My first thought after reading your answer was, how could that issue be related to my question, but soon I see. :rofl: Thanks for the hint! Now I understand why it have been closed for this long.
So since it's closed for an indisputable reason unrelated to any dev issues, I think it'd be better to have some explains that it won't be open for a while on the website for people looking for the API documentation. As it's now, people might consider that GL.iNet dev and support is bad or stopped. (Like this)
Thanks to you I got peace of mind to use the current API without considering about big changes.
Thank you.
If you request any API information, please contact support@gl-inet.com to obtain it.
