Hello, I just unpacked my new Flint 2 a few days ago. Played with it for a few days just to get a feel of the admin page and OpenWRT in general (first experience) and didn’t notice anything out of order, I think everything was working fine, incl. Channel Analysis graphs in LuCI.
After that, I did a factory reset using the System → Reset Firmware option from the web admin, to get back to stock settings and start configuring things for real. After the reset was finished, I noticed that the Channel Analysis graphs in LuCI are not populated even after waiting for a few minutes, no nearby wireless networks show on either the 2.4 GHz or the 5 GHz band. There definitely are nearby networks that should be detected, yet the page remains empty (after the text “Starting wireless scan…” disappears). This happens on any device, any browser I try, incl. incognito window and after clearing browser cache. In the browser’s Network console, there’s a bunch of 404 responses to requests for various JavaScript files, the list kind of resembles this report but I am not entirely sure that it’s related.
I didn’t install any OpenWRT packages, and besides configuring PPPoE credentials, wireless settings, DHCP/DNS and IPv6 via uci commands (since the necessary functionality is not exposed in GL.iNet’s admin panel), I don’t think I modified anything else.
Please let me know what other things I should check and try ![]()
- Which router (which model?) are you using?
- GL-MT6000 (Flint 2)
- Which firmware version is in use?
- 4.5.8
- How is your router connected to the Internet?
- By cable via the modem of my Internet provider
- ISP: Asahi Net
- Which DNS server do you use?
- Pi-hole DNS servers installed on Raspberry Pi Model 2 that’s available in local network
- Do you use DHCP or static IP addresses?
- DHCP, but not from DHCP server on the router itself – that one is disabled, instead Pi-hole acts as a DHCP server
