Choose specific location for Windscribe VPN servers via App
When selecting Windscribe servers via the android app there is no way to manually select a server within the selected country. Could this be altered so that we can choose a certain region within the country? For example there could be 3 french servers to choose on the official Windscribe app but I cant pick 2 out of the 3 as it always defaults to the same one, well actually you don't get a choice, it just connects to a french server, but it is always the same one.
This can be problematic if the server has been blacklisted but maybe you need to be appearing from France for example. if we could select the servers within the region then that would mitigate this happening.
It probably be related to the API of Windscribe & GL firmware, we will try to communicate with them whether it is feasible.
