Chromecast TV, Nest Mini, Problems with trying to connect
Hey @bruce here’s the syslog. I got my router back to 80 and rebooted it to get a clean syslog right aftet my Chromecas wasn’t able to connect to it
MT3000-chromecast-log-pdf.zip (98.9 KB)
Since seems the MT3000 repeat to primary router/AP, does the repeater link stable (op24 firmwre)?
What does the mean of back to 80?
Back to 80MHz, @bruce, Chromecast is able to connect fine when I set the bandwidth to 20MHz, that’s the problem that other people pointed in this thread
Checked, found some clients have connected, but we did not know which one client is the Chromecast.
Please share the syslog of the MT3000 when the Chromecast connected, better only it connected, other clients do not connect. Since we required to check the process of the Chromecast connected.
Hello, I am unsure if this is the correct thread, but thought I would give it a try.
I am currently trying to connect to a Roku TV and speakers through Cromecast on my guest network. All of my devices are connected to my guest network. which is in the 192.168.9.0-242 range. However, my mobile device, nor my Ipad can see any of the connected castable devices.
Any ideas on what could be causing this?
You mean "Cannot see" right? Then it should be normal becasue guest wifi has isolation.
You can turn that off.
