There is a possibility to bring wireguard support to Nord VPN on GL-MT6000?
There are some brands that have this support How to set the NordVPN WireGuard on TP-Link Wireless Router
Nord itself does not provide the config. So it would be a mistake, in my opinion, to support it on the router because it might cause problems and people would think it is officially supported.
You can always generate them by your own: https://nord-configs-crafter.pages.dev/
I think easy to use a phone app
For example I purchased pia vpn and there no possible to get config wireguard profile but possible use a phone app.
Additional information: In 4.7 beta (not yet available for all devices) is a setup for NordVPN WireGuard integrated! ![]()
That’s nice, I wonder what’s the process they did to support it because Nord doesn’t support WireGuard officially, they use NordLynx which is basically WireGuard though but they don’t allow you to download config files for this protocol, which is annoying, there’s ways to get the credentials but not practical
Gl-mt6000 have this update?
Yes, but only in 4.7 MTK Beta
We are waiting for openwrt 24😍
