Clients suddenly disconnect from Flint 2
Hi all, I have had my Flint 2 set up and configured for about a month now. I’ve tested it from different locations, everything has worked fine. However today the clients suddenly stopped connecting, despite the router being online. I have no idea why.
I tried to reconfigure the clients to see if that would help, but it didn’t work. Here’s the issue log:
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section wgserver2ovpnclient option 'src' specifies invalid value 'wgserver'
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section wgserver2ovpnclient skipped due to invalid options
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section wgserver2wan option 'src' specifies invalid value 'wgserver'
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section wgserver2wan skipped due to invalid options
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section lan2wgserver option 'dest' specifies invalid value 'wgserver'
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section lan2wgserver skipped due to invalid options
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section nat6 option 'reload' is not supported by fw4
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section gls2s option 'reload' is not supported by fw4
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section gls2s specifies unreachable path '/var/etc/gls2s.include', ignoring section
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section glblock option 'reload' is not supported by fw4
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Section vpn_server_policy option 'reload' is not supported by fw4
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Automatically including '/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft'
Tue Feb 13 15:00:08 2024 daemon.notice netifd: wgclient (8209): [!] Automatically including '/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft'
Tue Feb 13 15:00:09 2024 daemon.notice netifd: wgclient (8209): DROP all opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 match-set GL_MAC_BLOCK src
Tue Feb 13 15:00:10 2024 daemon.notice netifd: wgclient (8209): Failed to parse json data: unexpected character
Tue Feb 13 15:00:10 2024 daemon.notice netifd: wgclient (8209): uci: Entry not found
Tue Feb 13 15:00:10 2024 daemon.notice netifd: Interface 'wgclient' is now down
Tue Feb 13 15:00:10 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Tue Feb 13 15:00:12 2024 user.notice mwan3[8438]: Execute ifdown event on interface wgclient (unknown)
Tue Feb 13 15:00:14 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Can anyone advise how to resolve? I have an international trip coming in just a couple days and this has to be resolved before I leave!
What version in use?
And what kind of VPN provider? Is the contract still active?
Im wondering if this is your issue, its worth the try to temporary disable client block list?, or mac vpn policies?
Maybe this rule is not restored as disabled, or a regression in the firmware maybe?, in luci you can see if it reflects a block in luci → firewall → traffic rules, you can also extra check the portforwards but i think its only in the traffic rules tab.
