Hey guy. Im nit tech savy. But can anyone hell me out. Im currently using kaspersky antivirus. It scan my network and said that few port open, the following port that are open is 22, 23, 992, 2323.. How can i close it. Im using gl.inet e750v2 mudi.
22 is SSH and normal, since it's a Linux device. This port is only open from inside the LAN.
I would not recommend to disable SSH because if you have issues reaching your WebGUI it will be the only way to troubleshooting - without resetting the router.
