Hi, I installed the collectd ping plugins and at first the monitoring was correct, then it went from 10ms to over 44ms. From PC the ping is 10ms. What am I doing wrong?
My router Is MT6000
And you are shure to ping exactly the same host (IP address) ?
Yes same ip 8.8.8.8
Strange. I have the MT6000 for about 6 months. The ping is around 9 ms with occasionnaly peaks at 12 ms. I use my provider's DNS. Is your ping from the router now always over 44 ms ?
I found the problem, I am connected to a WIreguard VPN in another country on specific IPs and in fact it has the same latency as the VPN where it is connected even if the router should not be part of this connection
