I don't have a power supply for my Collie X300B, please may you advise if I can purchase from the UK store and which version I require.
If interested, it runs off Power Delivey, no problem (I run mine using a 12v trigger).
Barrel jack size is 55 x 21 (mm).
If you're considering purchasing from a UK store, look for suppliers that specialize in electronic components or audio equipment. Make sure to confirm whether you need a specific type of adapter (like a wall adapter or a battery pack) and check if it’s rated for use in the UK.
Yes I was surprised it's missing from GL's UK Store, I expected it to be available as an accessory.
I'm hoping to be advised that another model is compatible as the Velica, Opal, Beryl AX and Brume 2 all use USB C, and I don't know if the Marble is compatible.
The only power supply in the UK store is for the Slate AX
Picked up a etopgo from amazon, £8 with multiple connectors.
Now to find the SMB connectors.
