Comet GL‑RM1 gl‑pion high CPU
I’m using a GL.iNet Comet (GL‑RM1) running firmware V1.8.0 release3 in an intranet‑only environment with no internet access. In this configuration, the gl‑pion service consistently consumes a large amount of CPU. After tracing the behavior, it appears gl‑pion enters a continuous busy‑loop when the device cannot reach the cloud.
Environment
  • GL.iNet Comet (GL‑RM1)
  • Firmware: V1.8.0 release3
  • Device is intentionally offline (LAN‑only)
  • Cloud access not required
Observed behavior
When the device has no internet access, gl‑pion uses 10–35% CPU continuously.
Example from top:
982 root 20 0 589.1m 11.6m 33.3 1.6 111:05.59 S - gl-pion
strace evidence
strace shows gl‑pion repeatedly cycling through a futex/epoll loop with no sleep or backoff:
futex(0x9c6004, FUTEX_WAIT_PRIVATE, 0, NULL) = 0 futex(0x9c6004, FUTEX_WAIT_PRIVATE, 0, NULL) = -1 EAGAIN epoll_pwait(4, \[\], 128, 0, NULL, 0) = 0 write(5, "\\1\\0\\0\\0\\0\\0\\0\\0", 8)
This pattern repeats many times per second.
Impact
  • Sustained 10–35% CPU usage
  • Unnecessary load on the system in intranet only deployments
All other services (kvmd, ustreamer, janus, nginx, etc.) behave normally.
Workaround
Stopping gl‑pion eliminates the high CPU usage:
/etc/init.d/S99gl-pion stop
After stopping gl‑pion, CPU usage returns to normal and the system runs as expected in a LAN‑only environment.
Request
Is this is a known issue with gl‑pion on V1.8.0 release3 when the device has no internet access?
pion.strace.zip (23.5 KB)
system_logs_19700101_000110.zip (190.5 KB)
I can provide additional logs or testing if needed.
It is used to provide the WebTC FEC mode, and it also does not require access to the cloud.
