Hi there,
I have an odd two-PC setup for my streaming, and I wanted to add the KVM to my "Game PC" side of things.
My video card has 4 outputs, 3 DP and 1 HDMI, I use two DP to my monitors, 1 HDMI to my capture card, and 1 DP for the Comet.
Atm the setup is:
Outputs: 1,2 = monitors, capture = 3, KVM = 4
Capture clones monitor 1, KVM clones monitor 2.
So: [1|3*] [2|4]
Here's my problem:
The "main" monitor is 1, and the default behaviour of the KVM software seems to be to place the mouse at the top of "main" when you place the mouse in the screen, but because the mouse is off screen, you can't move it back on to the second monitor.
I propose a shortcut that centers the mouse in the middle of the KVM window, or teleports it between each monitor at the centre of the screen.
Hello! I'm having issues with the relative mouse setting on the KVM on version 1.3.0 release1. I am able to see the mouse on my secondary monitor that I have mirrored with the kvm but the mouse gets "flung" off the screen and relocated to the bottom or top of one of my other monitors if the mouse approaches the center of the screen.
I tested 3 monitors with different resolutions 4K/2K/1080p, my mouse is centered on screen 3, when I move to the left the mouse appears at the bottom of screen 2, this seems normal because screen 2 has less than half the vertical pixels of screen 3
I apologize but I don't fully understand how that relates to my issue. My issue is when I access the kvm, I'm mirrored to my second display (1440p) but the mouse shows up on my main display. With the relative mouse option enabled, I am able to click into the window in the KVM app and move my mouse to the second monitor that is mirrored to the kvm. But, as I move my mouse to the center of my second monitor (mirrored to the kvm) it gets flung to one of my other monitors. I can understand that my second monitor (resolution 1440p) has less pixels than my other monitors (both 4k), that doesn't fix the issue. Is there a way to fix this so this behavior doesn't happen? Maybe the mouse gets centered to which ever monitor the kvm happens to use or be mirrored to instead of the mouse being forced to be centered on what I chose my main monitor to be. Is that possible? Please excuse my ignorance.
