Is it possible to get an ultrawide screen resoluton 5120x1440 on a Comet PoE (GL-RM1PE) to work?
If so, what i have to do?
Thanks
Thanks
I expect the answer to this is no; the same as the Comet Pro (GL-RM10) which has the same video input specs.
no . can’t support resolution that wider than 4096
