Comet Pro GL-RM10 1.10.0r4: black video after macOS login, persists after KVM reboot
My Comet Pro remote picture froze on the macOS login screen after I entered my password, then became black. The Comet interface still works and reports an active stream. Rebooting the Comet did not restore the picture.
The controlled Mac remains responsive through a separate command connection. Diagnostics confirmed successful login. I need to recover the video without rebooting or logging out the Mac because applications are still running.
Setup
  • GL.iNet Comet Pro GL-RM10, firmware 1.10.0r4. The export confirms V1.10.0 release4.
  • Apple M4 Pro running macOS 27.0, build 26A428.
  • Mirrored displays. PA32QCV 6k and the (Comet) ROG PG248Q display identity at 1920x1080, 60 Hz.
Findings and recovery attempts
WindowServer logged "Failed to create mirror modes. Using offline mode." and display reconfiguration timeouts around the login transition.
The Comet logs show transient HDMI signal loss, encoder frame-retrieval failures, and a "width or height is out of range" error when the source changed to 0x0. Input later returned at 1080p/120, was lost again, and returned at 1080p/60.
I was changing settings while trying to recover the picture. Detecting HDMI timings also does not establish that valid desktop pixels reached the viewer.
A display-wake request and a brief 720p-to-1080p refresh were attempted. A separate 30-second unmirrored-display test automatically restored the original mirrored configuration afterwards. Still a black picture after the Comet reboot.
Selected diagnostic messages are attached PUBLIC-LOG-EXCERPTS.txt (1.3 KB)
It seems to pop up almost every time I switch users on my Mac, logging into a different account usually does it.
Could you provide the model of the controlled PC, the browser in use, and the transmission mode? Please try switching to WebRTC (native) and share the full logs.
as I said Apple M4 Pro Mac mini running macOS 27.0, build 26A428 machine I control
I use another Macbook to access it, macOS 27 as well
I use Safari and chrome, both have the same experience, as this is not a problem of external access, this is issue with Comet Pro GL-RM10 and Mac mini, where switch account mess something in screen sharing to Comet, where mirroring setting maybe fail in some way and screen freeze, screen freeze not only on remote access, it freeze on local Mac I want to control, and it does not come back until hard reset of Mac, holding on/off button for 12 seconds. I didn't find a way to unfreeze Mac screen from local access and not remotely. But all agents that running on Mac, run normally, so I can access them (using claude code mobile or other apps) and I don't see any performance issue with them, so it just some issue with display out signal from Mac mini that is failed and then does not recover until hard restart.
I tried all different transmission mode, I had WebRTC (native) when I first experienced it, but I switched and tried other modes, it does not effect this issue in any way. no I switched to WebRTC (native)
will share logs to dm
Would the problem still happen if you don’t connect to the RM10? This seems to be an issue with the controlled computer itself, or a security mechanism of macOS.
Of course, disconnecting rm10 did allowed me to switch profiles with no issues, when it was connected after logging to profile screen freezes
We attempted to reproduce this issue on the existing macOS 26.5.2; however, we were unable to observe the problem. It seems unrelated to rm10, so I’m afraid we cannot take further action.
