Hi. I have some of these KVMs wall-mounted. When wall-mounted with the screen facing upwards (of course), the display is upside down. Is there a way to rotate the display 180-degrees? If not, would I be able to do this physically by opening the units? Thanks!
Sorry changing the OLED rotation is not supported. Please be aware that disassembling the unit will void the warranty.
I wonder if it would be useful to create a wall mount STL so it can be mounted to have the screen orientation correct? It doesn't solve the issue that the screen will be at an awkward angle to read but at least the display would be the correct orientation.
That’s a great idea! I found some rack mount designs for holding the comet, and I think I have a 1U wall-mount somewhere, so that will do nicely. Thanks for the pointer
This may help get you started:
https://www.kickstarter.com/projects/glinet/comet-pro/posts/4474585
