Comet Pro (GL-RM10) — which KVMD `/api/*` endpoints work once unblocked?
I'm scripting a Comet Pro rather than using the web UI, and I understand the firmware has a KVMD core with /api/* disabled by default.
For anyone who has unblocked it:
  1. Does /api/msd/write + /api/msd/set_connected work — can you mount an ISO as virtual media via the API? This is the one I most need.
  2. Do /api/streamer/snapshot, /api/hid/events/send_key and /api/atx/power work?
  3. Does the change survive a reboot? Does it survive a firmware update?
  4. What auth does it use — the standard X-KVMD-* headers, or the internal token?
Also: does capture handle 720×400 @ 70 Hz text mode (legacy BIOS POST), or is it 1080p and above only?
Thanks — happy to write up whatever I find.
Sorry, but we currently have no plans for a public API. However, we can confirm that this resolution is supported.
/api/streamer/snapshot It should be noted that this API is available, but only when someone is accessing web; otherwise, you need to configure /etc/kvmd/override.yaml.
kvmd:
    streamer:
        forever: true
