This is the only thing that displays on the screen after startup. Touching either control results in nothing happening. I am able to access the KVM through the web interface and have configured it, and am using it. The screen never changes. I'm running version 1.10.1 Release 2 firmware. I've tried power cycling, and a full reset, which didn't work. Any ideas? I bought this because it had wifi and tailscale support, plus the touch screen. Seems like I could have bought one without a screen if it doesn't work.
Hi Thalia,
Here are the syslogs from the RM10.
The screen stays on the same page from startup. No update, and no response to touch.
Thanks,
Greg
system_logs_20261021_131815.zip (56.9 KB)
Hi, thanks for providing the logs. Unfortunately, it seems that this device may have a hardware issue.
Could you please email us the order information and include a link to this post in your email to support@gl-inet.com?
Our RMA team will follow up and assist you with the warranty process.
