Comet pro tailscale update
Hello, I own since few days a Comet Pro. Everything is working fine but when i connected it to my tailscale, I got a warning message from Tailscale that the version used (1.90.4) has known exploited vulnerabilities. Is there a way to upgrade tailscale? Fir example using the tailscale update command ?
Thanks in advance
`tailscale update` is fine
Where do you execute the tailscale update command? If I try to update on the Machines page of my tailnet, the update fails because the executable is not in the expected place. Do I need to SSH into the KVM?
Never mind…I found instructions to use Toolbox/Terminal. That worked perfectly.
@minmie Great, thanks for the answer. I just did it and it worked perfeclty.
