I setup a custom EDID for Comet-Q. However when I plug it into my mac the default GL KVM shows up as soon as the Comet-Q is connected and while it's booting up. Once I access the console on a different device does the custom one load which could be significantly later. Ideally the custom EDID should always load at boot or maybe it just doesn't load anything until it's ready. This should also extend to the USB device identity although I am actually not sure what happens at boot here. But it's the principle that the custom device identity that we set should always be persistent regardless of the device state.
Hi, this is the expected behavior in version v1.8.x. We'll fix this in a future firmware update. Thank you for your feedback.
