Comet x (GL-RM4PE V1.10.1 release3) - front USB ports not working - no keyboard/mouse power
new unit, the front usb ports never seem to power the mouse & keyboard connected to it. Same goes for the 3rd usb2.0 port on the front of the device.
HDMI display is working, though through the web interface, virtual keyboard doesn’t do anything/is unresponsive.
Have tried:
  1. using different USB/HDMI cables
  2. plugging into POE+++ port instead of regular POE+ port on switch (assuming maybe it wasn’t enough power) no change.
  3. using different keyboards/mice (WASD/HHKB Logitech G502 or Razer Death Adder)
  4. Confirming in Comet X settings that USB emulated devices keyboard & mouse are enabled (green)
  5. changing to one other device identity preset, but no change after reboot. (This section of config seems the only option left if the hardware is actually working.)
  6. firmware update
this has never worked, prior to and after the firmware update.
Is this a hardware defect or some type of configuration issue?
Hi, thanks for the detailed troubleshooting.
Could you please check your cable connection? The USB-C end should be connected to the USB port on the Comet X, and the USB-A end to a USB port on your controlled device.
I had a feeling it would be something simple. Yes, this was it.
Thanks for clarifying and helping me out.
