Comet X Loses keyboard
My new comet X keeps losing its USB mouse/keyboard. When I ssh into my system and do a lsusb, the glinet keyboard and mouse disappear every few minutes.
Hi, could you send the Comet X syslog and the model and OS of the controlled device you are using?
@Thalia Sorry, but after right at about 12 hours working with the Comet X, I ended up returning it to Amazon. I own a Comet Pro and on the same host, the Comet Pro works great. What I ended up diagnosing was that the Comet Pro would offer a composite Gli.net USB device for a keyboard and a pointing device.
The Comet X did the same, however logs on the connected Ubuntu 26.04 server (Miniisforum MS S1 Max 128GB Unified memory model) showed that the composite USB keyboard device was effectively disconnecting and timing out. I did a factory reset on the Comet X and even reloaded its firmware.
The end effect was that often the keyboard/mouse USB device never even presented or showed up briefly and vanished. Enumerating the USB bus often never saw it. I tried connecting the Comet X to three different USB busses on the host and each time the experience was the same.
I even disabled idle USB disconnects on the host and that didn't help. Meanwhile, my Comet Pro and two JetKVM's worked flawlessly.
I had planned to do a video on my "ScottiBYTE YouTube" channel highlighting the advantages of using a Comet X in the Homelab. As it turns out, I purchased the Comet X because I have four hosts that I wanted to control with it. I tried to connect two different hosts and they both reliably displayed video. The keyboard/pointer USB device offered from the Comet X despite seemingly running the same software as the Comet Pro, was just not stable.
I even noticed that a firmware upgrade was available and I took it hoping it would fix the issue. Nothing in the release notes seemed to address my USB issue. So, I ended up returning my Comet X Amazon order 114-8421175-2995449 today prior noticing your email. I wanted the Comet X to work really badly.
I really thought the Comet X looked like a great device and the ability to control four attached hosts coupled with much larger onboard storage for images was super attractive. However, the JetKVM can be be expanded with SD Card storage and the JetKVM supports booting disk images in addtion to ISOs. However, the video quality on the Comet Pro and Comet X are superior.
I am planning to do a video comparing the Comet Pro and the JetKVM. I can't see recommending the Comet X based on my testing, because it is clearly still in development and my experience demonstrated that it was not stable enough to be useful after my roughly 12 hours of testing.
I wish I had the log files for you. I can tell you that the USB keyboard/mouse either never enumerated on an attached host or they showed up for a minute or two and then ended up dropping until the Comet X was power cycled. During the entire time, video was always rock solid. However, no keyboard equals no control and that's the primary use case for an IP KVM.
I used the Comet X PoE powered and connected to a Ubiquiti Unifi USW Pro 48 PoE switch which is the same switch that I use my Comet Pro and JetKVM with a PoE splitter. I was excited that PoE was built into the Comet X.
My advice would be to suspend sales of the Comet X at least temporarily in order to protect the brand name while more testing can be done. The problem I noticed was absolutely consistent in the more than 75 tests I performed. Meanwhile, my Comet Pro and my JetKVM were absolutely reliable on the same host and the same USB ports on the same switch.
--Scott
Oh, and in addition to my description, realize that console port access to servers is the primary use case for an IP KVM. My entire 12 hour session had me continually feeling like I was being shot in the foot. An IP KVM is supposed to make life easier. I realized that a conventional 4 port wired KVM would have worked better from the start. Kudos on the Comet Pro because mine works great. The Comet X made me realize that not all good ideas are scalable. My frustration comes from the massive amount of time I spent in trying to make my job easier and this device did the opposite. An IP KVM has to work all the time and not just some of the time. It's the device you go to when all else fails. I just can't recommend the Comet X based on my 12 hours of repetitive failures.
Hi, thanks for the detailed feedback. We're sorry for the inconvenience. We'll forward this issue to our R&D team for further investigation. Thanks for taking the time to share this with us.
