Today i compared performance test of wireguard on same conditions. On gl.inet firmware 4.5 based on openwrt 21.02 i get 370 Mb/s, but on vanilla openwrt 23.05.2 i get 500 Mb/s. Interesting when developers will release new firmware based on new openwrt version.
Did you have any trouble/discover any issues flashing vanilla? This is only the second time I’ve ever seen anyone report flashing full OWRT on a Beryl AX. How’s the Wi-Fi speed, range, etc.?
I also didi it. The wifi range on vanilla OpenWRT is much better too.
Cheers
hi,
We are adapting mt3000 bases on openwrt23.05 and plan to release on v4.6.
It’s very simple:
- Get from OpenWrt Firmware Selector sysupgrade image.
- Go to System - Advanced settings in the web of router
- In LuCI go to System - Backup/Flash Firmware, push “Flash image” button and select file from step 1
4.After few seconds process complite. New address of router is 192.168.1.1 login root with blank password
If you want revert original firmware you need do this instruction.
About issues… I can’t run Wifi 5Ghz with 160Mhz width. Max speed is 700 Mb/s on this firmaware, when about 960Mb/s on original firmware with 160Mhz width.
