Device GL-MT300N-V2.
I built OpenWRT/LEDE from source as found here: https://github.com/gl-inet/lede-17.015 (Branch: lede-17.01) The resulting firmware uses kernel 4.4.92. However, wifi does not work, because there is no mt7628.ko in /lib/modules/4.4.92/
As a result, I use the image builder: GitHub - gl-inet/lede-imagebuilder-ramips-mt7628: Imagebuilder for ramips mt7628.. The kernel version for that is 4.4.93. That works well.
I now need to compile a package (gobi-serial and gobi-net) for 4.4.93. Obviously I can’t use buildroot because it uses 4.4.92.
As far as I can tell, I can’t compile packages using imagebuilder, only add the already-compiled .ipk files to the packages directory.
How can I compile the Gobi drivers for 4.4.93 for use with the image builder?
Thanks!
Joseph
