That’s a crazy setup! Quite interesting. One thought that immed. jumps to mind. The Flint v 1 (GL-AX1800) features a quad-core, 1.2 GhZ SOC. GL advertises it supports a max. of 120 connected clients. I naturally presume this relates only to AP association.
The Spitz AX (GL-X3000) uses a weaker, dual core, 1.3 GhZ. I think that’s probably a major bottleneck. You’d have to determine the max AP load it could handle before a client-side app could be considered for ‘batch uploading’.
@hansome : Do you guys have a number the Spitz AX can handle for @jammmet ?
This could be an issue since it will create high load. DHCP lease time of 2min means that there will be an new DHCP request of each device after only 60seconds - since half of the lease time is usually the time the device wants to renew the address.
