Configure Nginx Proxy On Openwrt
Hi there i have a beryl ax router and what i want it to do, is to add a cutom header e.g “X-CLIENT-NAME: MYNAME”, and so with the help of ai i was able to add this to nginx config on top of glinet’s basic config:
index gl_home.html;
lua_shared_dict shmem 12k;
lua_shared_dict nonces 16k;
lua_shared_dict sessions 16k;
init_by_lua_file /usr/share/gl-ngx/oui-init.lua;
# SSL Configuration for api.wifiyanidday.com
server {
    listen 443 ssl;
    server_name api.wifiyanidday.com;
    # SSL Configuration
    ssl_certificate /etc/nginx/api.wifiyanidday.com.crt;
    ssl_certificate_key /etc/nginx/api.wifiyanidday.com.key;
    # Add custom header with client's local IP address
    add_header X-ROUTER-NAME "Nidday Mark";
    # Proxy to backend service
    location / {
        proxy_pass https://api.wifiyanidday.com;
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_ssl_verify off;  # Disable SSL verification for the remote API
        proxy_ssl_server_name on;
# Additional server block for other routes (like /rpc, /ws, /upload, etc.)
server {
    listen 80;
    listen [::]:80;
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name _;  # Default server for all other requests
    ssl_certificate /etc/nginx/nginx.cer;
    ssl_certificate_key /etc/nginx/nginx.key;
    resolver 127.0.0.1 ipv6=off;
    rewrite ^/index.html / permanent;
    # Other locations
    location = /rpc {
        content_by_lua_file /usr/share/gl-ngx/oui-rpc.lua;
        add_header Content-Type application/json;
        add_header X-Frame-Options DENY;
    location = /ws {
        content_by_lua_file /usr/share/gl-ngx/oui-ws.lua;
    location = /upload {
        content_by_lua_file /usr/share/gl-ngx/oui-upload.lua;
    location = /download {
        content_by_lua_file /usr/share/gl-ngx/oui-download.lua;
    location /cgi-bin/ {
        include fastcgi_params;
        fastcgi_read_timeout 300;
        fastcgi_pass unix:/var/run/fcgiwrap.socket;
    location ~.*\.(html|png|jpg|svg)$ {
        add_header Cache-Control "private, no-store, no-cache, must-revalidate, proxy-revalidate";
    include /etc/nginx/gl-conf.d/*.conf;
I added the first server block, but when i tested it with curl, my traffic never went through ngix, it went directly to the remote server, so no header was set, so i googled and found out i needed to update my routers dns to match any traffic from my api.wifiyanidday.com to my nginx server at 192.168.8.1, and it did route it there, but then when i test it with curl without the proxy pass and just a text return, it works, but when i added my server as the proxy pass, i get:
root@GL-MT3000:~# curl -v -k https://api.wifiyanidday.com
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
> GET / HTTP/1.1
> Host: api.wifiyanidday.com
> User-Agent: curl/7.83.1
> Accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
< HTTP/1.1 502 Bad Gateway
< Server: nginx/1.26.1
< Date: Sun, 09 Feb 2025 23:01:19 GMT
< Content-Type: text/html
< Content-Length: 157
< Connection: keep-alive
<html>
<head><title>502 Bad Gateway</title></head>
<body>
<center><h1>502 Bad Gateway</h1></center>
<hr><center>nginx/1.26.1</center>
</body>
</html>
root@GL-MT3000:~#
What am i doing wrong in my config, or is there a better way to do this on glinet routers. All i need is to attach a custom header. I’ll appreciate any help i can get. Thanks!
What is your goal and why?
nginx isn't a transparent proxy for all traffic like squid.
So abit of background:
  1. I have a node server running on gcloud
  2. I have a website running on vercel
  3. I have multiple glinet routers running in different locations
My goal is to get a custom header attached to every request, only related to the domain of my server, with the custom name of the router and the ip address of the device making the request.
When a device wants to access internet or any other function from my router they have to login into the website (Command Center) and click on what they want to do. When they do that, the command is sent to my server and my server needs to identify on which router the device is sending the request, and send SSH commands to the correct router. I can also automate alot of stuff with my server without limits. Most browsers like chrome block you from sending any requests directly to my router cause it has a self-signed certificate. Browsers also recently don't allow you to access the device's local ip address.
