Configure ZeroTier on BE9300
Hi there!
I’m considering the GL.iNet GL-BE9300 and would like to know if it’s easy to configure ZeroTier on it.
I need to use it to connect and control one piece of equipment in my studio and another one at the show remotely.
Would you recommend this model for that kind of setup?
Thank you very much for your time and help!
As long as those GL router models support ZeroTier, I think it will be easy to configure it.
Here you go:
