How do I go about configuring the switch on the GL-MT300N-V1 to disable the wifi radio under /rc.button/ ?
What are the exact commands?
This would be a great feature by default.
Is this really necessary? I am afraid some people accidentally turned off the wifi and will blame the router defective.
I have some hints in another post.
I had plugged the wan into the lan and the lan into the wan and spent 20 minutes trying to figure it out. Is it necessary to create a lesser product for everyone, just for some stupid minds? It would be a great feature. I disable all my wifi devices before I sleep so I don’t fry my brains anymore than they already are; Thank you so much.
Here is what the staff had told me in email:
The correct script for the switch button is /etc/init.d/initswitch
You can have a try to edit the script. Add the red text
Turn on wifi when switch on left side
Line 57:
"noop")
uci set wirless.@wifi-iface[0].disabled=0
uci commit wireless
wifi on
Turn off wifi when switch on left side
Line 70 (before editing):
“noop”)
uci set wirless.@wifi-iface[0].disabled=1
uci commit wireless
wifi off
I’ve been thinking about configuring the switch to turn on and off a wireguard connection. I would love to learn how to do it.
Can you explain how to edit this file. I can’t seem to access root
use winscp to edit files Modify files on the router - GL.iNet Docs
Thank you, I have already edited the files appropriately and got it working. I just don’t think that should be the only option.
Seeing how many times it has been requested i thought they would do something by now
