Configuring USB modem with Slate
Hello all.
The Slate works great, but I have a Pantech UML290VW that I can’t seem to get to work. According to the docs, the modem is compatible and should work. The documents further say that it works in QMI mode. I’ve recently learned and installed Luci and was able to find the QMI mode but I still can’t get this thing to work.
Anyone have a tutorial or walk through?
Thanks!
You do not need to install luci.
Can you find the modem device in the default UI?
When you install the modem, pls also try to ssh to the router and get the logs
dmesg
logread
ifconfig -a
ls /dev
Hey thanks for the reply and sorry for this delay! How do I paste the terminal code? There’s a lot of characters.
root@GL-AR750S:~# dmesg
[ 0.000000] Linux version 4.14.221 (glinet@ubuntu) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11257-5090152ae3)) #0 Mon Feb 15 15:22:37 2021
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc)
[ 0.000000] MIPS: machine is GL.iNet GL-AR750S (NOR/NAND)
[ 0.000000] SoC: Qualcomm Atheros QCA956X ver 1 rev 0
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat 805d3a90, node_mem_map 81008400
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] random: get_random_bytes called from start_kernel+0x98/0x494 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 122400K/131072K available (4419K kernel code, 160K rwdata, 1008K rodata, 1252K init, 218K bss, 8672K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 51
[ 0.000000] CPU clock: 775.000 MHz
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 4932285024 ns
[ 0.000007] sched_clock: 32 bits at 387MHz, resolution 2ns, wraps every 5541893118ns
[ 0.008230] Calibrating delay loop… 385.84 BogoMIPS (lpj=1929216)
[ 0.074770] pid_max: default: 32768 minimum: 301
[ 0.079790] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.086776] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.097887] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.108284] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.114798] pinctrl core: initialized pinctrl subsystem
[ 0.121321] NET: Registered protocol family 16
[ 0.132210] PCI host bridge /ahb/pcie-controller@18250000 ranges:
[ 0.138638] MEM 0x0000000012000000…0x0000000013ffffff
[ 0.144180] IO 0x0000000000000000…0x0000000000000000
[ 0.165078] PCI host bridge to bus 0000:00
[ 0.169407] pci_bus 0000:00: root bus resource [mem 0x12000000-0x13ffffff]
[ 0.176690] pci_bus 0000:00: root bus resource [io 0x0000]
[ 0.182554] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[ 0.189711] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.198080] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
[ 0.198132] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[ 0.198184] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.198254] pci 0000:00:00.0: supports D1
[ 0.198262] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 0.198443] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
[ 0.198466] pci 0000:00:00.0: BAR 0: assigned [mem 0x12000000-0x121fffff 64bit]
[ 0.206217] pci 0000:00:00.0: BAR 6: assigned [mem 0x12200000-0x1220ffff pref]
[ 0.216174] clocksource: Switched to clocksource MIPS
[ 0.222458] NET: Registered protocol family 2
[ 0.227793] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.235140] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.241897] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.248734] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.254900] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.261777] NET: Registered protocol family 1
[ 0.266445] PCI: CLS 0 bytes, default 32
[ 0.269002] Crashlog allocated RAM at address 0x3f00000
[ 0.275668] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.286792] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.292940] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.312717] io scheduler noop registered
[ 0.316897] io scheduler deadline registered (default)
[ 0.323850] pinctrl-single 1804002c.pinmux: 544 pins at pa b804002c size 68
[ 0.331685] gpio-export gpio-export: 1 gpio(s) exported
[ 0.337975] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.346775] console [ttyS0] disabled
[ 0.350575] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 9, base_baud = 1562500) is a 16550A
[ 0.359706] console [ttyS0] enabled
[ 0.367270] bootconsole [early0] disabled
[ 0.392647] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.397588] 5 fixed-partitions partitions found on MTD device spi0.0
[ 0.404142] Creating 5 MTD partitions on “spi0.0”:
[ 0.409122] 0x000000000000-0x000000040000 : “u-boot”
[ 0.414940] 0x000000040000-0x000000050000 : “u-boot-env”
[ 0.421157] 0x000000050000-0x000000060000 : “art”
[ 0.426725] 0x000000060000-0x000000260000 : “kernel”
[ 0.432472] 0x000000260000-0x000000e20000 : “nor_reserved”
[ 0.441902] spi-nand: Mxic SPI NAND was found.
[ 0.446545] spi-nand: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 0.454445] 1 fixed-partitions partitions found on MTD device spi0.1
[ 0.461027] Creating 1 MTD partitions on “spi0.1”:
[ 0.465985] 0x000000000000-0x000008000000 : “ubi”
[ 0.819413] found bad block 5180000
[ 0.900112] libphy: Fixed MDIO Bus: probed
[ 1.576523] libphy: ag71xx_mdio: probed
[ 1.583505] switch0: Atheros AR8337 rev. 2 switch registered on mdio-bus.0
[ 2.237635] ag71xx 19000000.eth: connected to PHY at mdio-bus.0:00 [uid=004dd036, driver=Atheros AR8216/AR8236/AR8316]
[ 2.249242] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
[ 2.257246] NET: Registered protocol family 10
[ 2.265690] Segment Routing with IPv6
[ 2.269614] NET: Registered protocol family 17
[ 2.274250] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.287647] 8021q: 802.1Q VLAN Support v1.8
[ 2.297609] UBI: auto-attach mtd5
[ 2.301061] ubi0: attaching mtd5
[ 2.586176] random: fast init done
[ 7.106830] ubi0: scanning is finished
[ 7.163654] ubi0: attached mtd5 (name “ubi”, size 128 MiB)
[ 7.169376] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 7.176486] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 7.183494] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 7.190694] ubi0: good PEBs: 1023, bad PEBs: 1, corrupted PEBs: 0
[ 7.196993] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
[ 7.204453] ubi0: max/mean erase counter: 3/2, WL threshold: 4096, image sequence number: 796008383
[ 7.213803] ubi0: available PEBs: 0, total reserved PEBs: 1023, PEBs reserved for bad PEB handling: 19
[ 7.223495] ubi0: background thread “ubi_bgt0d” started, PID 320
[ 7.233072] block ubiblock0_0: created from ubi0:0(rootfs)
[ 7.238794] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
[ 7.265639] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 7.279846] Freeing unused kernel memory: 1252K
[ 7.284526] This architecture does not have kernel memory protection.
[ 8.208495] init: Console is alive
[ 8.212206] init: - watchdog -
[ 11.470474] kmodloader: loading kernel modules from /etc/modules-boot.d/
[ 11.676402] usbcore: registered new interface driver usbfs
[ 11.682127] usbcore: registered new interface driver hub
[ 11.687729] usbcore: registered new device driver usb
[ 11.702318] exFAT: Version 1.2.9
[ 11.739183] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 11.754036] SCSI subsystem initialized
[ 11.763123] ehci-platform: EHCI generic platform driver
[ 11.768799] ehci-platform 1b000000.usb: EHCI Host Controller
[ 11.774665] ehci-platform 1b000000.usb: new USB bus registered, assigned bus number 1
[ 11.782865] ehci-platform 1b000000.usb: irq 13, io mem 0x1b000000
[ 11.816215] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1.00
[ 11.823325] hub 1-0:1.0: USB hub found
[ 11.827564] hub 1-0:1.0: 1 port detected
[ 11.832152] ehci-platform 1b400000.usb: EHCI Host Controller
[ 11.838078] ehci-platform 1b400000.usb: new USB bus registered, assigned bus number 2
[ 11.846302] ehci-platform 1b400000.usb: irq 14, io mem 0x1b400000
[ 11.876219] ehci-platform 1b400000.usb: USB 2.0 started, EHCI 1.00
[ 11.883355] hub 2-0:1.0: USB hub found
[ 11.887608] hub 2-0:1.0: 1 port detected
[ 11.895206] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 11.903408] ohci-platform: OHCI generic platform driver
[ 11.911503] uhci_hcd: USB Universal Host Controller Interface driver
[ 11.922432] usbcore: registered new interface driver usb-storage
[ 11.930997] usbcore: registered new interface driver uas
[ 11.937306] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 11.955174] init: - preinit -
[ 12.886248] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 13.151987] random: procd: uninitialized urandom read (4 bytes read)
[ 13.158994] hub 2-1:1.0: USB hub found
[ 13.165873] hub 2-1:1.0: 4 ports detected
[ 13.616350] random: jshn: uninitialized urandom read (4 bytes read)
[ 13.706246] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
[ 13.818828] random: jshn: uninitialized urandom read (4 bytes read)
[ 13.901878] usb-storage 2-1.1:1.0: USB Mass Storage device detected
[ 13.916649] scsi host0: usb-storage 2-1.1:1.0
[ 14.176074] urandom_read: 4 callbacks suppressed
[ 14.176081] random: jshn: uninitialized urandom read (4 bytes read)
[ 14.997823] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ: 0 ANSI: 0
[ 15.010118] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 15.826561] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.832652] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 16.917540] eth0: link up (1000Mbps/Full duplex)
[ 16.922400] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.929212] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.1: link becomes ready
[ 19.065767] mount_root: loading kmods from internal overlay
[ 19.138664] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 19.150043] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 20.206589] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” started, PID 502
[ 20.485635] UBIFS (ubi0:1): recovery needed
[ 21.056559] UBIFS (ubi0:1): recovery completed
[ 21.061235] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name “rootfs_data”
[ 21.069358] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 21.079623] UBIFS (ubi0:1): FS size: 112373760 bytes (107 MiB, 885 LEBs), journal size 5586944 bytes (5 MiB, 44 LEBs)
[ 21.090589] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
[ 21.097445] UBIFS (ubi0:1): media format: w4/r0 (latest is w5/r0), UUID 1DD59EF9-E91C-4669-8FD2-F93E15BFEAFC, small LPT model
[ 21.125994] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 21.181178] block: extroot: not configured
[ 21.185610] UBIFS (ubi0:1): un-mount UBI device 0
[ 21.190535] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” stops
[ 21.216283] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” started, PID 505
[ 21.854577] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name “rootfs_data”
[ 21.862726] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 21.872981] UBIFS (ubi0:1): FS size: 112373760 bytes (107 MiB, 885 LEBs), journal size 5586944 bytes (5 MiB, 44 LEBs)
[ 21.883949] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
[ 21.890798] UBIFS (ubi0:1): media format: w4/r0 (latest is w5/r0), UUID 1DD59EF9-E91C-4669-8FD2-F93E15BFEAFC, small LPT model
[ 21.950100] mount_root: loading kmods from internal overlay
[ 22.018169] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 22.038602] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 22.890688] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 22.930171] block: extroot: not configured
[ 22.948799] mount_root: switching to ubifs overlay
[ 23.067293] urandom-seed: Seeding with /etc/urandom.seed
[ 23.278164] eth0: link down
[ 23.299795] procd: - early -
[ 23.302867] procd: - watchdog -
[ 23.853725] random: jshn: uninitialized urandom read (4 bytes read)
[ 23.976140] procd: - watchdog -
[ 23.979918] procd: - ubus -
[ 24.226272] random: ubusd: uninitialized urandom read (4 bytes read)
[ 24.274592] procd: - init -
[ 28.447041] kmodloader: loading kernel modules from /etc/modules.d/*
[ 28.487222] urngd: v1.0.2 started.
[ 28.509434] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 28.552410] tun: Universal TUN/TAP device driver, 1.6
[ 28.596551] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 28.638857] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[ 28.871965] random: crng init done
[ 28.899887] Netfilter messages via NETLINK v0.30.
[ 28.907298] ip_set: protocol 6
[ 29.027510] Mirror/redirect action on
[ 29.061927] u32 classifier
[ 29.064735] input device check on
[ 29.068573] Actions configured
[ 29.247332] GACT probability on
[ 29.277324] Simple TC action Loaded
[ 29.374989] fuse init (API version 7.26)
[ 29.412003] usbcore: registered new interface driver cdc_acm
[ 29.417901] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 29.467972] usbcore: registered new interface driver cdc_wdm
[ 29.490700] Loading modules backported from Linux version v4.19.161-0-gdaefdc9eb24b
[ 29.498666] Backport generated by backports.git v4.19.161-1-0-g4bb568fe
[ 29.579240] Ebtables v2.0 registered
[ 29.608865] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 29.616646] usbcore: registered new interface driver ipheth
[ 29.868448] ctnetlink v0.93: registering with nfnetlink.
[ 30.242619] usbcore: registered new interface driver usbserial
[ 30.248769] usbcore: registered new interface driver usbserial_generic
[ 30.255568] usbserial: USB Serial support registered for generic
[ 30.309341] wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
[ 30.318113] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld [email protected]. All Rights Reserved.
[ 30.497211] xt_time: kernel timezone is -0000
[ 30.528969] usbcore: registered new interface driver cdc_ether
[ 30.540416] usbcore: registered new interface driver cdc_ncm
[ 30.708185] usbcore: registered new interface driver cp210x
[ 30.714009] usbserial: USB Serial support registered for cp210x
[ 30.772527] usbcore: registered new interface driver huawei_cdc_ncm
[ 31.020271] PPP generic driver version 2.4.2
[ 31.049951] PPP MPPE Compression module registered
[ 31.075386] NET: Registered protocol family 24
[ 31.101585] usbcore: registered new interface driver qmi_wwan
[ 31.140519] usbcore: registered new interface driver rndis_host
[ 31.241226] usbcore: registered new interface driver sierra
[ 31.247118] usbserial: USB Serial support registered for Sierra USB modem
[ 31.299949] usbcore: registered new interface driver sierra_net
[ 31.410371] PCI: Enabling device 0000:00:00.0 (0000 → 0002)
[ 31.418525] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
[ 31.796917] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
[ 31.808014] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 37.013986] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
[ 37.042841] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/firmware-6.bin failed with error -2
[ 37.053938] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 37.223518] firmware ath10k!QCA9887!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
[ 37.431329] ath10k_pci 0000:00:00.0: qca9887 hw1.0 target 0x4100016d chip_id 0x004000ff sub 0000:0000
[ 37.440904] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[ 37.453727] ath10k_pci 0000:00:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,ignore-otp,skip-clock-init,mfp,allows-mesh-bcast crc32 62f7565f
[ 37.500628] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/board-2.bin failed with error -2
[ 37.511439] ath10k_pci 0000:00:00.0: Falling back to user helper
[ 37.605681] firmware ath10k!QCA9887!hw1.0!board-2.bin: firmware_loading_store: map pages failed
[ 37.630514] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 546cca0d
[ 38.703377] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file max-sta 128 raw 0 hwcrypto 1
[ 38.847586] ath: EEPROM regdomain: 0x0
[ 38.847592] ath: EEPROM indicates default country code should be used
[ 38.847595] ath: doing EEPROM country->regdmn map search
[ 38.847608] ath: country maps to regdmn code: 0x3a
[ 38.847612] ath: Country alpha2 being used: US
[ 38.847615] ath: Regpair used: 0x3a
[ 38.923412] usbcore: registered new interface driver option
[ 38.929294] usbserial: USB Serial support registered for GSM modem (1-port)
[ 38.996517] usbcore: registered new interface driver rt2800usb
[ 39.085383] ath: EEPROM regdomain: 0x0
[ 39.085391] ath: EEPROM indicates default country code should be used
[ 39.085394] ath: doing EEPROM country->regdmn map search
[ 39.085406] ath: country maps to regdmn code: 0x3a
[ 39.085411] ath: Country alpha2 being used: US
[ 39.085414] ath: Regpair used: 0x3a
[ 39.097377] ieee80211 phy1: Selected rate control algorithm ‘minstrel_ht’
[ 39.098986] ieee80211 phy1: Atheros AR9561 Rev:0 mem=0xb8100000, irq=2
[ 39.109739] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 56.969245] IPv6: ADDRCONF(NETDEV_UP): lo: link is not ready
[ 57.334494] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 58.732506] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 58.740012] eth0: link up (1000Mbps/Full duplex)
[ 58.744814] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 58.779666] br-lan: port 1(eth0.1) entered blocking state
[ 58.785247] br-lan: port 1(eth0.1) entered disabled state
[ 58.791157] device eth0.1 entered promiscuous mode
[ 58.796112] device eth0 entered promiscuous mode
[ 58.870231] br-lan: port 1(eth0.1) entered blocking state
[ 58.875815] br-lan: port 1(eth0.1) entered forwarding state
[ 72.787915] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
[ 72.857503] br-lan: port 2(wlan0) entered blocking state
[ 72.863001] br-lan: port 2(wlan0) entered disabled state
[ 72.868793] device wlan0 entered promiscuous mode
[ 72.873743] br-lan: port 2(wlan0) entered blocking state
[ 72.879268] br-lan: port 2(wlan0) entered forwarding state
[ 73.210841] br-lan: port 2(wlan0) entered disabled state
[ 75.528656] br-lan: port 2(wlan0) entered blocking state
[ 75.534169] br-lan: port 2(wlan0) entered forwarding state
[ 933.601920] device wlan0 left promiscuous mode
[ 933.606769] br-lan: port 2(wlan0) entered disabled state
[ 935.874009] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
[ 935.938576] br-lan: port 2(wlan0) entered blocking state
[ 935.944116] br-lan: port 2(wlan0) entered disabled state
[ 935.949857] device wlan0 entered promiscuous mode
[ 936.120943] br-lan: port 2(wlan0) entered blocking state
[ 936.126457] br-lan: port 2(wlan0) entered forwarding state
[ 947.042134] device wlan0 left promiscuous mode
[ 947.046821] br-lan: port 2(wlan0) entered disabled state
[ 949.463591] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
[ 949.510164] br-lan: port 2(wlan0) entered blocking state
[ 949.515702] br-lan: port 2(wlan0) entered disabled state
[ 949.521471] device wlan0 entered promiscuous mode
[ 949.696763] br-lan: port 2(wlan0) entered blocking state
[ 949.702298] br-lan: port 2(wlan0) entered forwarding state
[ 1109.039336] device wlan0 left promiscuous mode
[ 1109.044018] br-lan: port 2(wlan0) entered disabled state
[ 1112.090945] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
[ 1112.141735] br-lan: port 2(wlan0) entered blocking state
[ 1112.147276] br-lan: port 2(wlan0) entered disabled state
[ 1112.153025] device wlan0 entered promiscuous mode
[ 1112.258832] br-lan: port 2(wlan0) entered blocking state
[ 1112.264344] br-lan: port 2(wlan0) entered forwarding state
[ 1271.777204] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1271.983782] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 1272.015632] qmi_wwan 1-1:1.5: cdc-wdm0: USB WDM device
[ 1272.021876] qmi_wwan 1-1:1.5 wwan0: register ‘qmi_wwan’ at usb-1b000000.usb-1, WWAN/QMI device, 16:fc:3d:01:ff:18
root@GL-AR750S:~# logread
Tue Jul 20 13:13:19 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:13:22 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:13:27 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:13:28 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786803&sign=339e2931fea2f2e71a66c488d8f1ecdc
Tue Jul 20 13:13:28 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:13:32 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:13:36 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786811&sign=5e661a97ae01a52e981eee12217d6312
Tue Jul 20 13:13:36 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:13:37 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:13:42 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:13:45 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786820&sign=0443ee3dd4afca1215857fc225dd97aa
Tue Jul 20 13:13:45 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:13:47 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:13:52 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:13:53 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786828&sign=1b7c98553943e14d4cd5c1c72348aed8
Tue Jul 20 13:13:53 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:13:57 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:02 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786837&sign=2b27b543ab8acc0adcc0d7d6cf8cd48a
Tue Jul 20 13:14:02 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:14:02 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:07 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:11 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786845&sign=c2fa73c17a73257f04a7316dd15c790e
Tue Jul 20 13:14:11 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:14:12 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:17 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:19 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786854&sign=c032eda5897362d503886f9fbea41bf4
Tue Jul 20 13:14:19 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:14:22 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:27 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:27 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786862&sign=3cb28bb10bff907d0ddd50eb66b81765
Tue Jul 20 13:14:27 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:14:32 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:36 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786871&sign=ddf70b63679d31b1c0a28f6fc1938739
Tue Jul 20 13:14:36 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:14:37 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:43 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:44 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786879&sign=706fa238665db03f131f55fa411a547c
Tue Jul 20 13:14:44 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:14:48 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:53 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:14:53 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786888&sign=c3931f6bba1a63f04fbe8e4d051b2e14
Tue Jul 20 13:14:53 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:14:58 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:01 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786896&sign=1cf449e276b0bdf51f3b6a8c3e8e1786
Tue Jul 20 13:15:01 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:15:03 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:08 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:09 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786904&sign=0738254685d11ea682f62d19efb0b27b
Tue Jul 20 13:15:09 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:15:13 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:18 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:18 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786913&sign=6f6fbd259d3f2d39d70f3d8aa525b377
Tue Jul 20 13:15:18 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:15:23 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:26 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786921&sign=cbf53af368662386a2f4f923f21842bc
Tue Jul 20 13:15:26 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:15:28 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:33 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:35 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786930&sign=8066dcba295cdb7d04aa94301b0787a5
Tue Jul 20 13:15:35 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:15:38 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:43 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:43 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786938&sign=79e2701e72527a7d5319b7df0d951063
Tue Jul 20 13:15:43 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:15:48 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:52 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786946&sign=c03e0d90a8d35c9c51b16458d1d0deec
Tue Jul 20 13:15:52 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:15:53 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:15:58 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:00 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786955&sign=45aa653a00f7f0eb0545dce8cd17cd4c
Tue Jul 20 13:16:00 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:16:03 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:08 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:08 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786963&sign=95ec8316e3db938efe836aef4efb4418
Tue Jul 20 13:16:08 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:16:13 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:17 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786972&sign=5da8d8522c266ad7117801a8c6cda948
Tue Jul 20 13:16:17 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:16:18 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:23 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:25 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786980&sign=a753750eb7e583319756625dfdd54411
Tue Jul 20 13:16:25 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:16:28 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:33 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:34 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786989&sign=b5b661fab28af15f2d6f1cea6b1bf147
Tue Jul 20 13:16:34 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:16:38 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:42 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626786997&sign=fe9827095ca8ffdfbe6a8290de6296ac
Tue Jul 20 13:16:42 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:16:43 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:48 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:51 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787006&sign=642f903a1380513531e3483e68c95265
Tue Jul 20 13:16:51 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:16:53 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:58 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:16:59 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787014&sign=739b50aa66c94a3d3f6b5996439b3760
Tue Jul 20 13:16:59 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:17:03 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:08 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787023&sign=7df7e0aeb4ddd444a708f0545ae877bb
Tue Jul 20 13:17:08 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:17:08 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:13 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:16 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787031&sign=211ae295f64d3076724310bbbf8d85e5
Tue Jul 20 13:17:16 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:17:18 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:23 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:25 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787040&sign=04dd0735624e64e5ddba6c8727721b80
Tue Jul 20 13:17:25 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:17:28 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:33 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787048&sign=41f6a8786a74f89f7fed846bc089209d
Tue Jul 20 13:17:33 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:17:33 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:38 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:41 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787056&sign=8d200da027cf0811a604a1ff7da87060
Tue Jul 20 13:17:41 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:17:43 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:48 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:50 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787065&sign=fab39777ae4ed7adccb3bf25e3f7f322
Tue Jul 20 13:17:50 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:17:53 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:58 2021 daemon.info hostapd: wlan0: STA 5e:88:72:a9:ae:de IEEE 802.11: authenticated
Tue Jul 20 13:17:58 2021 daemon.info hostapd: wlan0: STA 5e:88:72:a9:ae:de IEEE 802.11: associated (aid 1)
Tue Jul 20 13:17:58 2021 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 5e:88:72:a9:ae:de
Tue Jul 20 13:17:58 2021 daemon.info hostapd: wlan0: STA 5e:88:72:a9:ae:de RADIUS: starting accounting session A3A5D69F99A5F03F
Tue Jul 20 13:17:58 2021 daemon.info hostapd: wlan0: STA 5e:88:72:a9:ae:de WPA: pairwise key handshake completed (RSN)
Tue Jul 20 13:17:58 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787073&sign=a909053282f3945759cd2535c5ac9a0a
Tue Jul 20 13:17:58 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:17:58 2021 daemon.info dnsmasq-dhcp[7478]: DHCPREQUEST(br-lan) 192.168.8.207 5e:88:72:a9:ae:de
Tue Jul 20 13:17:58 2021 daemon.info dnsmasq-dhcp[7478]: DHCPACK(br-lan) 192.168.8.207 5e:88:72:a9:ae:de Bradleys-iPhone
Tue Jul 20 13:17:58 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:17:59 2021 daemon.info hostapd: wlan0: STA 6a:52:ac:76:85:18 IEEE 802.11: authenticated
Tue Jul 20 13:17:59 2021 daemon.info hostapd: wlan0: STA 6a:52:ac:76:85:18 IEEE 802.11: associated (aid 2)
Tue Jul 20 13:17:59 2021 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 6a:52:ac:76:85:18
Tue Jul 20 13:17:59 2021 daemon.info hostapd: wlan0: STA 6a:52:ac:76:85:18 RADIUS: starting accounting session DC133561687AEB14
Tue Jul 20 13:17:59 2021 daemon.info hostapd: wlan0: STA 6a:52:ac:76:85:18 WPA: pairwise key handshake completed (RSN)
Tue Jul 20 13:17:59 2021 daemon.info dnsmasq-dhcp[7478]: DHCPREQUEST(br-lan) 192.168.8.241 6a:52:ac:76:85:18
Tue Jul 20 13:17:59 2021 daemon.info dnsmasq-dhcp[7478]: DHCPACK(br-lan) 192.168.8.241 6a:52:ac:76:85:18 BradleypleWatch
Tue Jul 20 13:18:03 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:18:07 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787082&sign=14eb9cc7e79c5fdc74194f6cc4fe8fcf
Tue Jul 20 13:18:07 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:18:08 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:18:13 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:18:15 2021 daemon.err gl_mqtt_service[3106]: url = https://gslb-us.goodcloud.xyz/gslb/getbucket?deviceType=1&mac=xxxxxxxx&sn=xxxxxxxx&ddns=xxxxxxxx&timestamp=1626787090&sign=2412fb893aefa5625aa44fad0f4cc0fb
Tue Jul 20 13:18:15 2021 daemon.err gl_mqtt_service[3106]: utils_NLB failed!
Tue Jul 20 13:18:19 2021 user.info : Function:net_maintain_health_cancelable Line:228 wifi_check_ssids_is_ok
Tue Jul 20 13:18:19 2021 daemon.info dnsmasq[7478]: exiting on receipt of SIGTERM
Tue Jul 20 13:18:19 2021 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Tue Jul 20 13:18:19 2021 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Tue Jul 20 13:18:20 2021 daemon.notice netifd: VLAN ‘eth0.2’ link is down
Tue Jul 20 13:18:20 2021 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Tue Jul 20 13:18:20 2021 daemon.notice netifd: wan (7541): udhcpc: read error: Network is down, reopening socket
Tue Jul 20 13:18:20 2021 daemon.notice netifd: VLAN ‘eth0.2’ link is up
Tue Jul 20 13:18:20 2021 daemon.notice netifd: wan (7541): udhcpc: received SIGTERM
Tue Jul 20 13:18:20 2021 daemon.notice netifd: Interface ‘wan’ is now down
Tue Jul 20 13:18:20 2021 daemon.notice netifd: Interface ‘wan’ is disabled
Tue Jul 20 13:18:20 2021 daemon.notice netifd: Interface ‘wan’ is enabled
Tue Jul 20 13:18:20 2021 daemon.notice netifd: Interface ‘wan’ is setting up now
Tue Jul 20 13:18:20 2021 daemon.info dnsmasq[18223]: started, v
Let me know if you need more. Thanks for your help.
From the log, the router has registerred as qmi modem. So you should be able to find the modem in the web admin panel.
You haven’t send me the output of the following command
ifconfig -a
ls /dev
ifconfig -a
br-lan Link encap:Ethernet HWaddr 94:83:C4:0B:D0:7C
inet addr:192.168.8.1 Bcast:192.168.8.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:499501 errors:0 dropped:0 overruns:0 frame:0
TX packets:592367 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:186761369 (178.1 MiB) TX bytes:544668114 (519.4 MiB)
eth0 Link encap:Ethernet HWaddr 94:83:C4:0B:D0:7C
inet6 addr: fe80::9683:c4ff:fe0b:d07c/64 Scope:Link
RX packets:499507 errors:0 dropped:0 overruns:22 frame:0
TX packets:644791 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:195752771 (186.6 MiB) TX bytes:565170790 (538.9 MiB)
Interrupt:4
eth0.1 Link encap:Ethernet HWaddr 94:83:C4:0B:D0:7C
eth0.2 Link encap:Ethernet HWaddr 94:83:C4:0B:D0:7C
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:52402 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:17921484 (17.0 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:66287 errors:0 dropped:0 overruns:0 frame:0
TX packets:66287 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6571302 (6.2 MiB) TX bytes:6571302 (6.2 MiB)
teql0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:1500 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wwan0 Link encap:Ethernet HWaddr 2A:30:73:7E:15:BA
inet6 addr: fe80::2830:73ff:fe7e:15ba/64 Scope:Link
RX packets:1173 errors:0 dropped:0 overruns:0 frame:0
TX packets:1478 errors:76860 dropped:0 overruns:0 carrier:0
RX bytes:96924 (94.6 KiB) TX bytes:152306 (148.7 KiB)
ls /dev
bus mtd5ro ttyS10
cdc-wdm0 mtdblock0 ttyS11
console mtdblock1 ttyS12
cpu_dma_latency mtdblock2 ttyS13
full mtdblock3 ttyS14
fuse mtdblock4 ttyS15
gpiochip0 mtdblock5 ttyS2
hwrng net ttyS3
kmsg network_latency ttyS4
log network_throughput ttyS5
memory_bandwidth null ttyS6
mtd0 port ttyS7
mtd0ro ppp ttyS8
mtd1 ptmx ttyS9
mtd1ro pts ubi0
mtd2 random ubi0_0
mtd2ro sda ubi0_1
mtd3 shm ubi_ctrl
mtd3ro tty ubiblock0_0
mtd4 ttyACM0 urandom
mtd4ro ttyS0 watchdog
mtd5 ttyS1 zero
Thank you for the help!
Two things: I got the modem to work by removing the APN settings and leaving it blank. It eventually reverts back to “internet”, but upon a reboot it gives me an IP. I’ve attach before and after pictures.
Here’s the output of the commands after I reboot. However, the modem looses connection very shortly after. Not sure what that is all about…
RX packets:500817 errors:0 dropped:0 overruns:0 frame:0
TX packets:593321 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:187024991 (178.3 MiB) TX bytes:544925837 (519.6 MiB)
RX packets:500823 errors:0 dropped:0 overruns:22 frame:0
TX packets:645874 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:196040081 (186.9 MiB) TX bytes:565476963 (539.2 MiB)
Interrupt:4
TX packets:52531 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:17965602 (17.1 MiB)
RX packets:66425 errors:0 dropped:0 overruns:0 frame:0
TX packets:66425 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6583307 (6.2 MiB) TX bytes:6583307 (6.2 MiB)
inet addr:166.166.54.233 Bcast:166.166.54.235 Mask:255.255.255.252
RX packets:1382 errors:0 dropped:0 overruns:0 frame:0
TX packets:1673 errors:77110 dropped:0 overruns:0 carrier:0
RX bytes:116127 (113.4 KiB) TX bytes:173316 (169.2 KiB)
ls /dev
bus mtd5ro ttyS10
hwrng net ttyS3
mtd0 port ttyS7
mtd0ro ppp ttyS8
mtd1 ptmx ttyS9
mtd1ro pts ubi0
mtd2 random ubi0_0
mtd2ro sda ubi0_1
mtd3 shm ubi_ctrl
mtd5 ttyS1 zero
Better to input correct APN also choose qmi in the protocol.
When lose connection do you mean IP disappear or the modem device disappears?
If the later it should be that the router cannot provide enough power
What should the correct APN be? I can not get an IP address with any of the options. When I refresh the screen, it defaults to “internet”.
The IP disappears. Currently it is gone.
As of right now, there is no internet connectivity.
root@GL-AR750S:~# ifconfig -1
ifconfig: -1: error fetching interface information: Device not found
root@GL-AR750S:~# ifconfig -a
RX packets:520249 errors:0 dropped:0 overruns:0 frame:0
TX packets:607531 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:190513367 (181.6 MiB) TX bytes:549267286 (523.8 MiB)
RX packets:520255 errors:0 dropped:0 overruns:22 frame:0
TX packets:665319 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:199878233 (190.6 MiB) TX bytes:571686562 (545.2 MiB)
Interrupt:4
TX packets:57766 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:19755972 (18.8 MiB)
RX packets:73611 errors:0 dropped:0 overruns:0 frame:0
TX packets:73611 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7283567 (6.9 MiB) TX bytes:7283567 (6.9 MiB)
RX packets:3171 errors:0 dropped:0 overruns:0 frame:0
TX packets:3882 errors:88090 dropped:0 overruns:0 carrier:0
RX bytes:260880 (254.7 KiB) TX bytes:406654 (397.1 KiB)
root@GL-AR750S:~# ls /dev
bus mtd5ro ttyS10
hwrng net ttyS3
mtd0 port ttyS7
mtd0ro ppp ttyS8
mtd1 ptmx ttyS9
mtd1ro pts ubi0
mtd2 random ubi0_0
mtd2ro sda ubi0_1
mtd3 shm ubi_ctrl
mtd5 ttyS1 zero
The correct apn depends on your cellular provider. If you are not sure what the correct apn is Google may be able to help. Without the correct apn you have zero chance of getting a connection.
It is connected but data transfer is not good. Can you set ttl to 65?
I’ve done pretty extensive Google searches on the correct APN. The problem is, this modem is very old. The last real literature on this modem it’s almost 10 years old. Everything is saying to use VZW Internet. That does not work and I do not get an IP address. The only thing that works is to leave field blank, save, then reset the modem. It works for about an hour then quits.
Right now, there is no IP address. It is not working. But shortly after it goes down, the IP address remains but I just can’t get any data transfer. It eventually lets go of the IP address at some point.
How do sets ttl to 65?
You posted screen capture above. In the setting there is ttl settings.
OK I’ll make the change. What exactly does that do?
