yes, 192.168.1.100 is a camera connected to the router.
I must set a correct IP for the camera ? example, 192.168.8.100 ?
And, can I set port forwarding directly from the router, right ?
Just setup a wireguard VPN and allow local access make sure its running then setup the client on your other end then connect and you should be good to go.
I have VPN connected, and from the router (my laptop) I can ping other PiVPN Wireguard client (10.6.0.19, 10.6.0.20…) but from the PiVPN server (VPS) I can’t ping my router client 10.6.0.10 and the camera 192.168.8.108 . Maybe the problem is the firewall ? Do you have a tip for forward the router and the camera ? Please check image attach.
Thank you very much for your help !
If the IP address must match the subnet. If your camera use static IP, you must change it to 192.168.8.x which match the subnet of the router. But you can change the router’s IP to 192.168.1.x as well.
