Connect GL-AR300M mini router to wifi hotspot, then wired to home router
My ISP connection failed and they wont send a tech until Monday. Is it possible to use my Android phone as a wifi hotspot, connect the mini router to it, then connect the mini router to my home router via LAN cable? If so, how? I cant figure out how to get the mini to connect to my phone hotspot…
TIA
I don’t want to use the wifi signal coming from the mini router. The range is limited. I was hoping to hard wire (ethernet cable) connect it to the LAN input on my main ASUS house router. That would also connect internet to all the wired devices in my house as well. Btw, where does that screen(shot) appear?
Appear when login to the main web interface. If your UI is different try to find it.
Thanks, appreciate the help.
