Hello all,
I am using GL-AX1800 router and I recently bought the Huawei E8372 that I am trying to use with a SIM card. I have plug it in the usb port of the GL-AX1800 router, however it is not shown inside the admin page.
I have tried so far:
- E8372 works both as a wifi and usb provider. The sim card is activated, so all good with this device
- I changed the ip of E8372 so it doesn’t overlap with the GL-AX1800
- GL-AX1800 works with ethernet cable connection
However, I think GL-AX1800 and Huawei E8372 are not compatible to connect using the usb port. Anyone aware for any settings that needs changing ?
Thank you very much!
