Connect through 5Ghz
I use my GL-750S-ext set as router connected to the telco router. The GL-750S-ext is connected to the telco via 2.4Ghz. I want to connect to the telco router via 5Ghz.
The telco router uses the same SSID for both the 2.4Ghz and the 5Ghz.
How do I tell the GL-750S-ext to use the 5Ghz radio?
Thanks
So you selected 5G when setting up repeater and it connect to 2.4G automatically?
No, that’s not what happened.
I think that I selected 2.4Ghz when I setup (I didn’t pay attention at the time). Now I want to change it to 5Ghz.
Thank you
You can disconnet, remove the saved ssid and set up again to your 5G SSID I think.
I was hoping for some drop down box or radio button to edit the save network.
Thanks
