i bought the GL-MT300n-V2 and i have the newest firmware and i want to connect to a hidden wifi. In Luci there is no menu for wifi. Network > Wifi does not exist. Screenshot by Lightshot ← these are the only menu
sorry for bad english thank for help
Actually, you can set it in admin web page. We had remove Wireless in Luci for MT300N-V2, due to it uses closed wireless driver, which isn’t compatible with Luci.
Thank you for your reply. But with this function i only can hide the wifi from my router, but i want connect my MT300-V2 to a wifi that is hidden. (Repeater Mode) I hope you can unterstand me.
Got it, unfortunately, we have filter the hidden AP in repeater mode. In this case, you have to ssh to the router, and configure it via uci. You also can change to other model, which supports Luci, such as ar150, ar300m.
uci set wireless.sta.ssid=SSID
uci set wireless.sta.channel=1
uci set wireless.sta.key=wifikey
uci set wireless.sta.bssid=bssidhere
uci set wireless.sta.encryption=psk2
uci commit wireless
Are these commands correct?
And how do you connect?
Step 1: connect to a non-hidden SSID. This will create rules of network and firewall etc.
Step 2: Disable repeater manager which will change repeater automatically.
killall /usr/bin/gl_health
mv /usr/bin/gl_health1
Step 3: Connect manually
uci commit wireless
/etc/init.d/network restart
The router will always try to connect to the same ssid even it is not available.
Now it work! Thank you very much! ![]()
Here a guide for other people:
First, connect to a non-hidden SSID
Then kill the process gl_health and move the file
killall gl_health
mv /usr/bin/gl_health /usr/bin/gl_health1
Now connect
uci set wireless.sta.ssid=yourssid
uci set wireless.sta.channel=yourchannel
uci set wireless.sta.key=yourwifikey
uci set wireless.sta.bssid=yourbssidhere
uci set wireless.mt7628.channel=yourchannel
uci commit wireless
Restart network
Important: You must also set the wifi-device ‘mt7628’ to the same channel otherwise it will not work.
Does this procedure stops normal operation to work when you want to connect to normal broadcasting SSIDs?
Thanks,
You do not need to connect to hidden network by modifying the UCI.
After scan go to the bottom of the list and choose others, then you will be able to type ssid manually.
I know this is an old thread, but I just got a gl-sft1200 router, updated to the latest firmware, and am trying to use in Bridge mode with a hidden SSID. Not working. I then tried to use this SSID in repeater mode and that works... until I reboot. Then it times out which trying to reconnect. I cannot connect to it until I deleted the saved SSID, then readd. Works fine until a reboot. How can this be done.
