The GL750(S) models scan the WLAN frequencies for active access points and display those which transmit their SSID. So far, so good. The user can select one and connect.
But how does the user connect to a known access point which does NOT transmit its SSID? Not only a small number are configured that way. Even my cell phone has a dialogue “Add a new network” where I can manually input an SSID and - if necessary - a passphrase. If the network is within reach, the phone will connect even when the SSID was invisible. Either I don’t see this option or it is indeed missing in the GL750 products. I cannot comment on other iNet models.
The complicated solution offered in subject “connecting to a hotel wifi (MT300A sees it as hidden ssid)” cannot really be meant serious; this customer who started the other subject was clearly overwhelmed with the task. The real solution for all WLANs with suppressed SSID is so easy: Let the customer enter the SSID.
BTW: I like the automatic cross-reference to possibly similar subjects which pops up
