can someone explain to me how to connect an uart-adapter to an AR300M?
I cannot see any connectors…
And is it 3.3 or 5V?
Many thanks!
Many thanks!
It is 3.3V. You have to solder the pins by yourself.
Ok, but how do you open it?
<span style=“line-height: 1.5;”>I’ve seen the video on how to open the light blue model and that has a little “dent” where you can prise it open. </span>
I don’t have such a dent on my ar300m and at the moment I am having troubles getting at it…
Flip your router over so that you can see the white product label and it’s upside down. There’s a minuscule gap almost directly above the ROHS logo at the seam of the case. Actually, it’s slightly on the left hand side of the circular logo.
Dig in with a small pen-knife and go for it. Takes a bit of work the first time.
GL!
Got it.
Many thanks!
