I currently have a Mesh wireless network using the IP addresses 192.168.1.1-192.168.1.254, is it possible to connect my GL-MT1300 Beryl router to this network so that it and devices connected to the GL-MT1300 Beryl get their IP addresses from the Mesh network but can also route via the GL-MT1300 Beryl VPN using VPN Policies.
I have tried this with the GL-MT1300 Beryl using it’s default 192.168.8.X setting but that means the 192.168.8.x devices cannot access the 192.168.1.x devices.
My Mesh network has very limited configuration options.
I have thought about buying the GL-B2200 Velica 2-pack but I don’t believe it allows for a seperate 2.4Ghz ‘Smart’ network and it also needs at least one additional LAN port on the Main node.
