GL-MT1300 is my main router ( router#1)
I’m running home vpn server using GL-MT300N-V2 router(i.e router#2) which is behind router#1.
I’m able to connect to home vpn server from outside my lan.
Is it possible to connect router#1 as vpn client to router#2? I would like to run my own vpn server and connect my main router to it.
Please help. thanks in advance.
Note. when I used the wireguard config in router#1, It didn’t successfully connect(amber color status was on) to router#2 vpn. I also already done port forwarding and even excluded router#2 from router#1’s vpn exclusion policy.
when I connect rounter#1 to router#2(i.e home vpn server), network speed is reduced to 1/3 of normal speed(i.e without home vpn) which is significant speed reduction. is that expected? how I can improve it? thanks in advance.
another issue. I have two GL-MT1300 routers. when I tested both router with wired and no vpn , seeing different speed. one gives 270mbps and second one gives me 90 mbps. any reason why this difference? thanks in advance.
