I have setup an OpenVPN access server in the cloud and it runs fine and I can connect my windows PC to it. The Windows client does not use a *.ovpn file but seems to import the certificate.
I then followed the instructions and created a user-locked certificate and it created 5 files
ca.crt
client.crt
client.key
client.ovpn
ta.key
Using the client.ovpn file does not allow the MT300N to connect. It gives the following error
OpenSSL: error:02001002:system library:fopen:No such file or directory
OpenSSL: error:2006D080:BIO routines:BIO_new_file:no such file
OpenSSL: error:140AD002:SSL routines:SSL_CTX_use_certificate_file:system lib
Cannot load certificate file client.crt
Exiting due to fatal error
The contents of the client.ovpn file is
# Automatically generated OpenVPN client config file
# Generated on Wed Aug 31 20:00:30 2022 by openvpn
# Default Cipher
cipher AES-256-CBC
# Note: this configuration is user-locked to the username below
# OVPN_ACCESS_SERVER_USERNAME=peter
# Define the profile name of this particular configuration file
# OVPN_ACCESS_SERVER_PROFILE=peter@129.151.88.29
# OVPN_ACCESS_SERVER_CLI_PREF_ALLOW_WEB_IMPORT=True
# OVPN_ACCESS_SERVER_CLI_PREF_BASIC_CLIENT=False
# OVPN_ACCESS_SERVER_CLI_PREF_ENABLE_CONNECT=False
# OVPN_ACCESS_SERVER_CLI_PREF_ENABLE_XD_PROXY=True
# OVPN_ACCESS_SERVER_WSHOST=129.151.88.29:443
# OVPN_ACCESS_SERVER_WEB_CA_BUNDLE_START
# -----BEGIN CERTIFICATE-----
# MIIDADCCAeigAwIBAgIEYw+q/zANBgkqhkiG9w0BAQsFADA5MTcwNQYDVQQDDC5P
# cGVuVlBOIFdlYiBDQSAyMDIyLjA4LjMxIDE4OjM5OjU5IFVUQyBvcGVudnBuMB4X
# DTIyMDgyNDE4Mzk1OVoXDTMyMDgyODE4Mzk1OVowOTE3MDUGA1UEAwwuT3BlblZQ
# TiBXZWIgQ0EgMjAyMi4wOC4zMSAxODozOTo1OSBVVEMgb3BlbnZwbjCCASIwDQYJ
# KoZIhvcNAQEBBQADggEPADCCAQoCggEBAMYz0Oxa/HORBlulgjwuqcUnDsqUMbpx
# pCJOXaotLfRdeutEl8jm8TP69Dj3aVis1BHyI+tcYbww4u1HNxw4C2Z5fPv+O13W
# Rc1hiF2ZCfulKQWcLqD6f9p81XxtuJZCia725JQelhgp1DuEGYkYGMpzb5oYoY1o
# qx1oRgEgtGSAJQ1x7OaHjrq7ETREzfCC8tAt2hpDV1KWajb3ikFQz4o0gAma+RPj
# qUWpYEWmJnLVTY8yhHFtu0O2/XQqPWCiraJ1TopjPUslVh9zhualtc0/fbBLjkEj
# OhusX643iMsGkHQxb+eRzYUtRpRIeb/HMidEJi1NcDXuasSTP9A/QRUCAwEAAaMQ
# MA4wDAYDVR0TBAUwAwEB/zANBgkqhkiG9w0BAQsFAAOCAQEAJjtvTm4aIUh/9IXA
# 04tcCOjw+wDp5VsPG6I3qQUQf0cWLM9PQn452LIvoaY+3oNjHFUJatdmID4yDai8
# AyvwRHmOQb+M9oqoORCLY80UrJ/sg3nh7dkkFqqDFbjEhPD1i8L/Pocl0vLJWknP
# xrAHH+RRiMczm4sXBsneGwYzZBDstmfjhAGutQf2DoARBrofuHtyf4Kn8QE4mbce
# E5K/gt7bft6C/7QY/VQp08d/QpjnDsC3SUR0Hgu5GiWNeC9HG3e3EnsFnG2wH0jL
# wk7UKD96ptbrRgXAiMroJNJZ4SUn5TOLi8yMQXAgnVyG9CKF/xkANdnCmNvx4O7G
# DxVSFg==
# -----END CERTIFICATE-----
# OVPN_ACCESS_SERVER_WEB_CA_BUNDLE_STOP
# OVPN_ACCESS_SERVER_IS_OPENVPN_WEB_CA=1
setenv FORWARD_COMPATIBLE 1
client
server-poll-timeout 4
nobind
remote 129.151.88.29 1194 udp
remote 129.151.88.29 443 tcp
dev tun
dev-type tun
ns-cert-type server
setenv opt tls-version-min 1.0 or-highest
reneg-sec 604800
sndbuf 0
rcvbuf 0
auth-user-pass
# NOTE: LZO commands are pushed by the Access Server at connect time.
# NOTE: The below line doesn't disable LZO.
comp-lzo no
verb 3
setenv PUSH_PEER_INFO
ca ca.crt
cert client.crt
key client.key
tls-auth ta.key 1
## -----BEGIN RSA SIGNATURE-----
## DIGEST:sha256
## bwieMTrJbGfldMf/rW3AQbkZIp1tVj2DUm4BAXRYJbdj0z7sgP
## ju7VjrmTQW+2zBqT5aRJSgTwQpb8SX7lAQmHHd0hr2q64LvtRl
## 9UbunK5AdeuB7ii0eTl3ainWFVSoZbQ77AUCSDcokSeWswxPBU
## wZqmaqcSi3etHKqoU8SI8kG5MgLHTW7P5SXhdPw9FfSrzUh1xp
## kqbIrP4+sAtoEtUb/AH6O32dnCjvtzJc334CXICWhegIHtaVzk
## C7KNrlKV+qg7PX/EGOcbl1PElVmK4RvfRzmNcdibROTAkVDAyz
## 20eEUXzrP8fg9K3ZdjZncr5t9aiAi2R+dvhKTjXuHw==
## -----END RSA SIGNATURE-----
## -----BEGIN CERTIFICATE-----
## MIIC6TCCAdGgAwIBAgIEYw+rADANBgkqhkiG9w0BAQsFADA5MTcwNQYDVQQDDC5P
## cGVuVlBOIFdlYiBDQSAyMDIyLjA4LjMxIDE4OjM5OjU5IFVUQyBvcGVudnBuMB4X
## DTIyMDgyNDE4NDAwMloXDTMyMDgyODE4NDAwMlowEjEQMA4GA1UEAwwHb3BlbnZw
## bjCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAMvsVMcmgVEnVh6xIZJd
## SHr3xvF64Woguv4wnGO46iCA8hw+mgmDck9+WQC0CbLyCqOLBDjHz2CeYsc6+J2t
## TVUrFoQcWi0+FWlPRgmtukR3xsF058vifp7BecQuNDNnREIpzyuseBQ4W+u5aQgh
## nqVwMP4/KqxIX29JesQ0J3DwQrIYevHUyXzf3vj6a+u1DRiARXdQdQzNwmaV1gvd
## RSbIWEOhRA8G0PKViE18GBKwFzpYsqe9aUAH3kIfPBlGr3hb/ew/MyoarAomvYBQ
## xeZEHMByMZy9kvqBZXyyQxLU45OQ+P8ksgeTqtXRaEh/9Qu3+dd+gkvg5tXrHs7z
## kCcCAwEAAaMgMB4wCQYDVR0TBAIwADARBglghkgBhvhCAQEEBAMCBkAwDQYJKoZI
## hvcNAQELBQADggEBAJvbZ6dyfMEmw35xoldIyjwZdVUacLzHfAcBy6K3uY0Fh92l
## tgFWpHkcem/WPsd1UZqkHCAMgbkq1tn0Vm6iGcIe8yxkEntU3gp0r993qr5Ep8nb
## 2Zi8IOHR5fxcx3JAbUOElvxM/juGVOFYNlzbPDEhozPF2D8NbTwXWA25kgmEr1ac
## fk/k+sM/BSCv1dj6CFfXpvwDuVHbbNo75gi3EwR8mSZ1pS98FILWgHYJ9lmKLEZr
## 72JdJnaWXcrjQ1V6WMZYU4bBRfvP79a11d4AtiezeUCE+XD3x6BSDr793p8akJ93
## 7QTwnVecAhMHCffFK2unok3kxLwmh6sTZ0t5Z9k=
## -----END CERTIFICATE-----
## MIIDADCCAeigAwIBAgIEYw+q/zANBgkqhkiG9w0BAQsFADA5MTcwNQYDVQQDDC5P
## DTIyMDgyNDE4Mzk1OVoXDTMyMDgyODE4Mzk1OVowOTE3MDUGA1UEAwwuT3BlblZQ
## TiBXZWIgQ0EgMjAyMi4wOC4zMSAxODozOTo1OSBVVEMgb3BlbnZwbjCCASIwDQYJ
## KoZIhvcNAQEBBQADggEPADCCAQoCggEBAMYz0Oxa/HORBlulgjwuqcUnDsqUMbpx
## pCJOXaotLfRdeutEl8jm8TP69Dj3aVis1BHyI+tcYbww4u1HNxw4C2Z5fPv+O13W
## Rc1hiF2ZCfulKQWcLqD6f9p81XxtuJZCia725JQelhgp1DuEGYkYGMpzb5oYoY1o
## qx1oRgEgtGSAJQ1x7OaHjrq7ETREzfCC8tAt2hpDV1KWajb3ikFQz4o0gAma+RPj
## qUWpYEWmJnLVTY8yhHFtu0O2/XQqPWCiraJ1TopjPUslVh9zhualtc0/fbBLjkEj
## OhusX643iMsGkHQxb+eRzYUtRpRIeb/HMidEJi1NcDXuasSTP9A/QRUCAwEAAaMQ
## MA4wDAYDVR0TBAUwAwEB/zANBgkqhkiG9w0BAQsFAAOCAQEAJjtvTm4aIUh/9IXA
## 04tcCOjw+wDp5VsPG6I3qQUQf0cWLM9PQn452LIvoaY+3oNjHFUJatdmID4yDai8
## AyvwRHmOQb+M9oqoORCLY80UrJ/sg3nh7dkkFqqDFbjEhPD1i8L/Pocl0vLJWknP
## xrAHH+RRiMczm4sXBsneGwYzZBDstmfjhAGutQf2DoARBrofuHtyf4Kn8QE4mbce
## E5K/gt7bft6C/7QY/VQp08d/QpjnDsC3SUR0Hgu5GiWNeC9HG3e3EnsFnG2wH0jL
## wk7UKD96ptbrRgXAiMroJNJZ4SUn5TOLi8yMQXAgnVyG9CKF/xkANdnCmNvx4O7G
## DxVSFg==
Can anybody advise me where I am going wrong
