I have downloaded the correct zip file which contains the needed ovpn, key, and cert, but when trying to apply I continually get an error message stating "You need to put your ca, key, crl, and cert in teh same zip file and upload. I have done this as well and still unable to get it going. Any suggestions?
You need to check your ovpn file, there are some lines e.g. “ca ca.crt”, indicating ca file is ca.crt
Although you have put these files in the same folder, but if the name is not correct, the router will report that it cannot find the correct file.
I am having the same problem. I have unzipped the file from untangle and moved everything into a single folder, edited the .config and .ovpn files to update the filenames for the crt, key, and -ca.crt files, and then zipped it back up.
I get the same error when I try to upload it to the OpenVPN page.
Did you ever end up getting this to work with Untangle? I am having similar problem using the latest firmware for the MT-300N V2. I tried the zip file and the single file with the certificates inline. The later imports fine but cannot connect. The zip uploads but asks for a passphrase?
It seems there have a untangle firmware, not sure how does it work. If you can send me your OpenVPN configuration files with certificate, I can have a check.
