Hello GL.iNet Support,
I recently purchased a GL-AXT1800 (Slate) router and I’m hoping to set up a wired internet connection to my Samsung S21 Ultra via router’s USB interface. I’ve heard that this might be possible, but I’d appreciate step-by-step guidance on how to accomplish this.
Additionally, I’d like to understand if I should disable the USB tethering option on the usb port before making this connection or if there’s a specific setting on the router I should be aware of. ATM when i connect s21 to usb port, i am getting only charging and Ethernet setting in my Connections menu is greyed out
Thank you for your assistance. Looking forward to your prompt response.
Best Regards, Maxim
