I’m not particualrly techie minded so forgive me if im missing something simple with my problem.
I am setting up my mini smart router, it is connected to mt BT Router via the WAN port and then connected to my BT vision box with the LAN cable.
I have succesfully connected to the internet and wi-fi works great but when I go to watch my sport channels, i get an error saying to check my broadband connection but when I look at the BT vision setting it says it is connected. I’ve restared the BT box, restarted the BT router but this hasn’t helped.
Any help in how to get it set up to recieve the sport channels would be much appreciated
I am connected to the mini router, via my laptop, good signal, good speeds, everthing working as it should be.
The TV box says it is “connected to broadband”
I can watch catch up TV, iplayer etc etc through the TV box
I can’t get my subscription channels, interestingly, the subscription channels appear on the tv guide with descriptions of whats on etc but as soon as I select a subscrption channel the tv screen goes black and I get the error.
I think the tv box is connected to the internet otherwise I wouldnt get the catch up services but it just won’t play ball with my sport channels!
