I have a Slate 7 (GL-BE3600) connected to a laptop on stage. If I connect a Shadow (GL-AR300M16-Ext) Mini Smart Router to the audio mixer at the back of the room, can I configure the router to create an Ethernet connection from the laptop to the mixer?
Yes, you can do the following:
- Connect the AR300M to the BE3600 via Ethernet or Wi-Fi.
- Then configure the AR300M to AP / Extender mode, so that devices connected to the BE3600 and devices connected to the AR300M are on the same subnet.
- After that, the laptop and the mixer can communicate with each other via LAN IP.
For how to configure AP / Extender mode, please refer to:
